slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Fri Apr 27, 2007 9:53 am
PS - I finished installing my 3.8L Taurus fan: works great. When I first installed it, I left the bottom trim as is, and rested it on the bottom lip of the rad. This caused clearance issues with a KA24DE intake. I had to trim quite a bit off the whole shrowd for it to fit properly. I hated to use the radiator zip ties, but I didn't have much choice. At least it is still resting on the bottom lip. Also I needed to cut the A/T coolant hose pipes off the rad (not used for a M/T application). The low speed works just fine on a stock relay and 30A fuse.
Cools great. PS - double check your wiring with a battery before installing: I miswired mine the first time and had to re-do it!
