sorry, i search coulding find out. Boost Question.
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
Ok years past, rebuilt number 2 is done, breaking in is almost over.
I've always read boost limits to18psi on stock bottom end, what is the weak point?
this is my setup:Nistune ECU tunning Walbero fuelpumpKA24 Throttle bodyZ32 Maf550cc injectorsGT28 s15 bb spec Rturbo back 3"exhaustss turbo manifoldfront mount intercoolerRebuilt motor new bearings/ringspolished cranktomei 256 camsFuel Pressure regulatoroil coolerfilter relocation kit, larger filteroil catch can
Whats stock:
Pistionsrodsvalves(replaced) but stockspringscranklifters
Whats the weakest part of my motor, how much boost can i handle without blowing up my stock pistions? Or my motor. I ask because i will be dyno tuning soon and I want to hit 300whp and i wanna know where i just gotta go F**k if i gotta give up without hitting 300whp .
I know it's a redunant question but didnt find anyone with setup close to mine to compair when i searched.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
On a dyno, get some ordinary fuel, and turn up the boost until it starts to ping.
That's the limit :-) If it goes bang..you have exceeded the limit.
High boost = higher risk. Gonna have to live with the timebomb :-)
XTCshri2222
trying to avoid that bang
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Your engine can handle whatever that s15 t28 can dish out. Just make sure the tune is spot on. I wouldn't run it much over 18psi though, as its going to be out of its efficiency range over about 20psi.
My setup is exactly the same.
I don't know if you are going to quite make 300whp, but 280 should be easily within your grasp. I'm shooting for ~270.
One question though, you have a wideband? I would highly suggest one.
XTCshri2222
i have access for wideband to use for tuning, but no i don't have one hardwired into the car.
new200guy
Car: 1990 Nissan 200sx
i agree with r34 gtr. you might get to 300whp. you should be good to go though with what you have. at around 350 hp you should consider upgrading internals
