Sorry for this one.. Please help S14 Blacktop into S13
cadence_1
I am just wondering if someone can point me in the right direction of some posts on putting the S14 Blacktop motor into and S13. I am sure it has been covered on here bunch but the search words I seem to be using arent really producing the results I would like.
Mainly I am looking for wiring differences between the two types of swaps. What needs to be done. I have wired many S13/S13SR's before so I dont really need any help on that.. Just what is specific to putting this S14 motor in the S13 chassis.
Again I am not looking for anyone to have to sit here and write it all out for me.. If you could just point me to some post I would very much greatful.
thank you,
CoupedUp
Car: 1993 Coupe
Seriously, there are NO posts. Noone has done a write up. Ive searched and searched and searched. And I had to reside to 4-5 Hours reading wiring diagrams in the S14 SR FSM.
The main differences are:
Power Interfaces are in totally different areas.Dash plug is integrated with the Power Interfaces and needs seperated.Alternator ring connector is of the wrong diameterStarter Female plug, is different and needs swapped.Wiring colors are not matched they are different in some areas.
Good luck. It wasn't too bad after i actually did it. But then again, i spent 4-5 hours reading the FSM and writing a write out on paper. : /.
cadence_1
Your swap looks very clean thank you or the reply.. Might anyone else have any more insight on this matter?
thanks.
CoupedUp
Car: 1993 Coupe
Meh, needs some tidying up, but thanks.
