Sorry, another i/c question(didnt wanna thread jack)
reu
Car: 89-240sx(x2)
i'm laying out my turbo set-up (T25) AND I HAVE TWO I/C'S?!?anyways one is a 1st gen dsm 4" thick 8" tall 6" across 2" in/out. the other has slightly more space between fins, dunno who made it?, it measures 3" thick 5" tall 25" across 2.5" in/out.which is better? which will keep temps down, hp up, and less lag? ??
steve s14
post up some pictures if you get a chance but i would guess the first one's core would flow better judging only by it's dimensions, but the inlets and outlets are small. since you are using a t25, it should be ok.
sil80drifter
Car: 1990 240SX Hatch
here's a stupid suggestion: weld them together and make an FMIC. or just get one from ebay for $200 shipped. they are that cheap nowadays.
i know i know it's not what you asked for, but i'm just givign suggestions, as most pople upgrade later anywya, so why not do it once and have the piping all there already for an even bigger FMIC. Heh. Sorry.
sil80
crzycav86
Car: 93 Nissan 240SX KAT
reu wrote:i'm laying out my turbo set-up (T25) AND I HAVE TWO I/C'S?!?anyways one is a 1st gen dsm 4" thick 8" tall 6" across 2" in/out. the other has slightly more space between fins, dunno who made it?, it measures 3" thick 5" tall 25" across 2.5" in/out.which is better? which will keep temps down, hp up, and less lag? ??
the 3x5x25 sounds like a small fmic. What are your power goals? You might as well use the fmic.
reu
Car: 89-240sx(x2)
your right the 25" is a front mount the reason i'm thinking of using the dsm is i dont want that big a pressure drop, my hp goal is 200 crank on the stock 7lbs but i want a fast spool.i hate lag!!!!!!!!!!!
reu
Car: 89-240sx(x2)
should i use 2" piping seeing that the intercooler ends are 2" or should i go 2.5" with reducers? the t25 has a 2" apt turbo adaptor for the charge side of the i/c or whatever.
j-z
Car: 95 240sx
i just ordered a 12x24x3 bar and plate off ebay for 140 shipped LOL. if you use the dsm side mount, for your piping i would go 2'' in and 2.25 out or 2.5 . wont matter that much at that low of power. i would def choose the fmic over the SM anyways. youll be running the same amount of piping with either cooler, and less chance of heat soak with the fmic. show yo grille bish!
reu
Car: 89-240sx(x2)
the frontmount i have looks like a screen door!!!!!!!!!!!!i just like oem factory parts cuz i got a stupid dump tube that they didnt even finish cuttin out the side dump so now i have to dremel and clean it out or cut and reweld it should have bought oem but hey it was basically free!(u get what u pay 4!, too bad im poor!!!!!!!) so ill go 2" turb to i/c n 2.25 or 2.5 i/c to throttle bod.thanks.
