DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Sat Nov 25, 2017 11:00 am
Welcome!
It's hard to pinpoint such things as you ask from such little information, we'd need a lot more such as test results to various items (injectors/harness/connectors) and more maintenance history to even guess. We are much better answering questions about test results from common areas of failure with the Z32.
On the surface though, soot is generally a fuel-related thing and since all 1990-1994 Z32's injectors fail and the harness and connectors also, I'd start looking and testing there using the online service manual you can download from our "everything you need to know...Z32" sticky. Ethanol in our gasoline and a wiring/electrical issue specific to the Z32 cause this injector failure, along with crappy connector corrosion and harness breakage due to heat.
There are other areas to look at as well such as if your exhaust system is newer and working right (bad cat), if your O2 sensor(s) are working, etc....too many things to go over here, but all is in the OSM along with the tests...good luck!
