hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Tue Jun 28, 2005 12:08 pm
there are screws on the bottom of the panel. then there is a screw or two on the side then you take off the door handle.. there's a screw in there. take the handle out. then remove the whole window operation/ door locking bezel. there's a screw in there also. then the panel comes out and there are a few bolts holding the speaker mount in place and that's about it. the door panel hangs on the door so you have to lift it up and out to get it off. it's all pretty easy to do. ask specific questions if you have any.
