my mevi is tied open. I was running 18psi but for some reason i cant make more than 12psi.allensteiner wrote:that's still a good time. i'm stock so would be far from that...but can't find out without a track
how much boost do you run? i thought you were up to 16psi.
edit: maybe the rpm switch is out of whack on your mevi?
But of course 24x12x4NewDad=4drs wrote:Are you running any sort of intercooler?
NewDad=4drs wrote:ok, just thinking about your top end power loss.
Air to air, I assume.
The one thing that a 75hp dry shot helped me with on my 16psi s/c Gen 2 Lightning was that it brought down my intake air temps significantly because 16 psi is over spooling the stock eatonbeyond it's efficient capacity. This was even compared to just running a power cooler full of ice water thru my intercooler with larger heat exchanger.
F/I just creates soo much heat that anything that brings down that intake air temp is awesome. I just wouldn't go too high with a dry shot.
I wont run a dry shot for personal reasons but charge cooling is one of the reasons for wanting to add N2O. The car is full weight and a dd so theres not much weight i can get rid of. I have a quarter tank of gas also.
IMO your 60ft time is very respectable for a FWD vehicle.
AcMav wrote:As a heads up he already said he is Intercooled. I think thats a damn fast time, for a street car i wouldn't even bother with nitrous and I'd consider weight reduction (Fiberglass Hood / Trunk Hood / Rear Seat Removal). How much gas did you have in the tank at the time? A full tank weights almost 180 pounds i believe, running near E could definitely get you into the 12's. I'd guess you have the spare tire removed but its worth mentioning.
Suspension surprisingly can add a good amount of time as well if you can keep the car well grounded.
Did you run Ice on the Intercooler for that run?
Nah no ice on intercooler. I actually had a car full of crap i.e jack stands jack easy 200 pounds of crap.
I Cant remember if you have a bubble or not on your sunroof, If so that should probably go
Just my 2 cents Cheers with the fast max
