TSL wrote:
Do you have one or not? Check the fuel mixtures.
That would be a good start.
Sorry the wideband thing I should have elaborated...it's in the car b4 the sensor craped out it was seeing about 14.5:1 at idle.The sensor crapping out was totally my fault had my fabricator weld the bung on my downpipe exactly where I told him to unfortunatley the sensor set up right against the frame .Anywayz bad frig up but the sensor worked long enough for me to start the car run it and check afr.
As for idle and timing well yeah it does need to be set but I don't think its the issue with the messed up idle...not ideal to drive yes but I won't be driving it until I get that stuff done this weekend.
