First of all yes i have been researching getting my KA24DE some boost. Second this is a project car and not my DD so if i break or blow it up thats ok.
here is the set up i have almost complete/plan to run
SR t251g SSAC manifold reinforceds13 SMICstock elbow/down pipe on stock exhauststock BPV recurculated to b4 turbo
SACF IIMSD BTMBlaster SS coil w/ DYI modSr370cc225lph pump
My compression came out to170.170.165.170
I want to run about 6psi on this setup until i can get a larger exhaust, new clutch and WBo2, new rad/electric fans
#1. Do i need to run coolant lines on the t25 if i install a turbo timer?
#2. i know i need to run colder plugs but how much colder for my setup?
#3. i plan install fuel pressure gauge, what kind of # should i expect to see running 6psi. would an AFPR be needed or will the SAFC be able to mantain the proper FPR?
#4 I want to remove the EGR system, but i understand that the EGR can accualy prevent detanation in F/I engins. is it better to keep the EGR or remove? ( emmission passing/inspection is not a problem)
#5 BOV vent/recurculate? i know many people prefer one over the other, i guess im the kind that like the BOV sound, i take it the SAFC can be tuned to decrease the fuel flow when shifting to allow for a vented BOV w/o backfire or insanley rich conditions?
