Soon to be boosted! Quick question
Silvia2NR
Car: 1992 240SX Coupe
I need some input concerning the oil lines. Do you guys think this is a good kit to use?
http://cgi.ebay.com/ebaymotors...wItem
thanks
Silvia2NR
or should i get this kit?
turbo2nr
Car: 97 240sx (kouki)
i like the 2nd one b/c it comes with the flanges for the turbo. which is usefull and seems more complete.
Silvia2NR
Yes i was thinkin the same, but I don't see a tee for the oil sender.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
You will need some sort of BSPT to NPT adaptor to be able to T off of the oil sender port. Look in the sticky and you can get everypart you need from mcmaster-carr
Silvia2NR
yes i tried mcmaster, but the price came up to $59......
Silvia2NR
I've decided to go with this kit..seems to be the most complete and extremely simple to install.
http://tunertoys.zoovy.com/product/OLK508
Chezedik
Car: 1991 Nissan 240sx
If you check the sticky, there is a setup that is very inexpensive.
crzycav86
Car: 93 Nissan 240SX KAT
If you don't want to piece it together, use this kit: http://www.cheapturbolines.com/
Chezedik
Not a bad setup either.
Silvia2NR
Thanks for the help guys
I bought the TunerToys kit because the oil line fitting the use for the pressure sensor is quite unique and avoids the need for multiple parts. I think it'll make for a neat look.
Silvia2NR
The oil line kit from turbo toys came today, gotta say im impressed. Very fast shipping. Excellent packaging, and top notch product. The "T" fitting they use is beautiful.
