labedra »
https://forums.nicoclub.com/labedra-u66522.html
Mon May 28, 2007 9:53 am
Hello everyone, I'm a newbee here and am also thinking of buying a 350Z. I'm planning to install Greddy TT kit in it up to 8PSI. Of course this woulod be done after exhaust, brake, suspension, and sway bar upgrade, etc. My goal is to drive this on track and on the weekends. I have a couple of questions below:
1. I plan to use the stock block and heads however I plan to replace the pistons, rods, and maybe cams, what is the max recommended milage on the engine before installing these components and a turbo?
2. In order to replace the pistons, rods and cams do I need to take this block and heads to machine shop I know the cams are a bolt on but no expereience with replaceing stock pistons with turbo ones. I plan on (9:1) compresion ?
3. If I do replace the pistons, rods, and cams does the eninge have to be brocken in before installing a Twin Turbo ?
4. I was planning to buy a 2003 however cuffuup28 recommeded on getting 2004 +, what are the major issues with the 03 model ?
Thanks!
Modified by labedra at 1:37 PM 5/28/2007
