i have read a DIY changing tie rods and tie rod ends , and he said that " loosen and almost remove the bolt on top of the outer tie rod, leaving 2 threads still connected.
due to when using ball hoint seperator , the ball joint will suddenly detach and violently pop out of the steering knuckle, if t his happen it will damage the inner tie rod ball joint, how is this posible?? just curious , does it really happen?
check this out:
http://g35driver.com/forums/br....html
