Jesda wrote:Its easy to fix. I posted how-to steps and pictures a year ago, but I have no idea where that thread is now. Search diligently.
[The best long-term solution is to throw it out, stomp on it, curse Sony, and buy a Clarion.]
Originally posted by bobotec on some markviii site========================================here is photo 1:
Click image for larger version
You can see i labeled the 2 swtiches lever switch 1 and 2.
Lever switch 1 is the easy one to bend up. I held the left part of it down and bent the right free edge up a tad (1/8-1/16 of an inch?)
For lever swtich 2, i had to slide the bar over to the right:
Bascially what I did was after I removed the back cover off the changer, i was able to rotate some of the gears that control the bar that ejects and injects the cd into the reader mechanism. (the red arrow on the right is pointing to where those gears are, you can't see them in the pic i took though).
Once I slide the "bar below" over to the right, it freed up the lever switch 2. I can't remember, but i think i held down the right pivot side with my screwdriver and then bent up the free left edge about the same as i did with lever switch 1.
Once that was all done, i slide the bar back to its home position by moving the gears back the other way (that is important, i beleive if you keep the bar in the "injected" position and then put the cartridge, it iwll then try to slide the bar back and break somethhing.
now for the cleaning, i don't have any pics of it, but what i did was to look at the back of the changer on the cd reader side. There was a tall bar that had a gear at the top of it, i was able to rotate the gear and the cd inject mechnanism then slide up towards the top. Once i got the cd inject mechanism near the top, i was then able to see the cd laser eye clearly. I then used 99 (70 percent will probably be fine) rubbing alchol and a wooden qtip and cleaned the laser eye gently yet somewhat firmly (i wasn't a wuss about it i mean).
Then i closed everything back up and it appears to be working now (and its reading old burnt cds, stuff that i burned like 3 or 4 years ago that i happened to have laying around).
