Sonar cap?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
infinitiex35owner
Car: Ex35 2010
The front sonar right cap is gone. :( Looks pretty ugly. After looking on accessory site, it appears the cap don't comes alone. I must buy the 200$ full sonar and the cap alltogheter. Any alternative?
sev
Car: 2010 Infiniti EX35
you can buy the entire sensor with a new cap from alibaba. I struggled with this a few years ago. same situation as you. That was the only route to go cheaply. Even then I think it cost 30-40 dollars a sensor. I can't remember.
You have to beg the seller to sell you one or two, because they will try to sell you a 1000. They were okay with doing that for me. I told them I wanted a few 'sample' parts before making my purchase decision. They were more than happy to send me 2 in that case.
http://www.alibaba.com/product-detail/I ... 1.2.mXwCW9
The 10-20/piece is at volume discount, the price goes up for just two.
centralcoaster33
Car: 1997 Nissan 240SX #5
pop one off of a wreck at the junkyard maybe? Could be a few similar ones out there that would fit... Good luck!
sev
every ex35 ive seen at the JY was destroyed from the front end. Probably wouldnt be an easy find
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
infinitiex35owner
Car: Ex35 2010
Looks like I am gonna need a full one. Only it's hard to be sure the part will fit exactly. I got a lot of part numbers variant.. At about 30$ i ain't got a lot to loose tough.
Thanks guys!
sev
that part, again, is not beveled slightly upwards. It might fit but the placement wont be exact, so just be aware
infinitiex35owner
Car: Ex35 2010
sev wrote:
Tue Jan 02, 2018 7:03 pm
What do you mean?
infinitiex35owner
Car: Ex35 2010
I ve found the parts number 25994-CM10D and 25994-CM13E to be broadly available at about 20$.
1. However, do you know any difference between them (25994-CM10D and 25994-CM13E) ?
2. And do you guys know if different colors exist to match my nbumper (grey)?
sev
infinitiex35owner wrote:
Tue Jan 02, 2018 9:12 pm
What do you mean?
the original sensor is points slightly upwards. With that part from mouser it will point straight, it slightly throws off the distance sensing
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
