Empty V »
https://forums.nicoclub.com/empty-v-u86973.html
Fri Jul 09, 2010 10:55 am
Well after 210,000 miles I finally blew a part in my xenon headlamps. My driver's side lamp turns off after about 15 seconds. I figured it was the ballast but it can't hurt to troubleshoot. I removed the grill, pulled forward both headlamp assemblies and swapped lamps. The issue did not follow the lamps, not good news. So then I swapped both ballasts and this time it followed. I knew this was going to be an expensive part but didn't think it would be this expensive. They range anywhere from $388-$600, just for the ballasts! I have yet to find a parts distributor that can get one and none of the junkyards within 20 miles have 01-04 QX4's. This is quickly becoming a pain.
