Somthing odd i noticed with the lsd out.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Well, my r32 lsd took a poop so i had venus rush one to Hawaii EXPENSIVE!! anyways , i was running the car in neutral last night with no diff in and noticed that my driveshaft was roatating and when i pushed the clutch in it stopped, it was rotationg about like 50rpm's any ideas? Bad clutch?
thanks
ehacker01
Car: 1995 240sx
Its normal.
gawdzilla
Car: none
huh? please clarify? wont the car move forward if the driveshaft is rotating?
EDIT: nevermind i see you said w/ no diff in...
but still, without a diff in and no resistance on the other end, the output shaft will rotate? whys that?
Joe
its normal
the sloshing motion of the fluid from the input shaft in the transmission turns the countershaft and then the output shaft even tho no gear is selected
gawdzilla
Car: none
ok i buy that... but basically its so weak that if you were to hold the driveshaft w/ your hand it wouldnt spin anymore right?
Joe
exactally.
RB20DETodd
Thanks guys, i got scared there for a bit like ,my clutch was gone.
