somthing interesting i just found out.
slw240sx
Car: 1990 Ca18det 240sx Hatch
well my friend comes over today he had been talking to another supra owner who knows alot more about car tuning then either of us put togther. well hes been talking to him about my car and its endless birage of problems. hes recomended i get the car leakdown tested to make sure i haveny bend or burnt a valve.the motor runs smooth and quiet idles steady and vacum decent . i dont think its the valves
im running 10psi of boost and got my new hot pipe on and iam and have been blowing alot of black smoke under boost. i hav for a while now . but we cant figure out where im running rich from. well tonight a new theory came about.
the walbro fuel pumps. which i and most of you use one are meant to run at 12volts all the time. well the CA and most cars have a system that runs pumps at a fluctuating voltage to quiet the pump and conserve power. this means that the pump isnt always running at the full 12v at lower RPM and idle its running between 6-8v thats about half of what the pump needs . and we think it maybe causing fueling issuse with my setup. as i get lean symptoms under cruiseing and i blow black clouds reminecient to early locomotives from the 1800s. there are products made in japan to elminate this but im not paying for it and so goes the weekend task of locating this system and taking it apart or just bypassing it so we get 12v to the pump at all times and hopefully keeping the fuel pressures constant and me running right
CA19DET
thast what i had in my CA19 Capri, you got to make sure to run a fuse between the pump and ignition source, i went through a couple pumpse cause of fualty wireing.
quest
lotsa SR swaps and turbo KAs run walbro. They don't have any issues. No wiring mods.Can't see valves causing a prob if you're idling smooth. They are a prob in the CA, but it'll run crappy.Have you checked your fuel pressure under all running conditions?fuel pressure reg governs it.... u know *regulates*U sure u have no boost leaks... had a hose with a small split that I looked over a few times, but it obviously opened when pressurized. Ran stinkin' rich under boost. $4 later car was pinning u in the seat. no more black smoke
Spectre_240sx
Car: 1990 240sx SE
SR's and KA's probably don't have the same voltage regulation system that the CA has. That's why the walbro works just fine for them. Thanks for the heads up slw, I'll make sure to keep that in mind when I do my swap. Is there anyone else here using a walbro that's experiencing the same problems?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
ask me in a week, i probably will be.
r34 gtr
off subject, but why do ricers list what plugs they have when they tell you the stuff theyve done to their car?! ooooh, youve got platinum plugs, now theres no way i can win! i guess ill go home now.
sorry, had to ask.
Nismo1182
Car: Z06
Ive got platinum plugs and I always seem to win :confused:
LOL, good point though.
slw240sx
bottom of page check it out!
http://www.tomei-p.co.jp/_2003....html
also i am in the process of changing every single hose that passes air in my system and redoing the wiring, just need to get some free time an be awake before 3pm
alfred183
What about using a fuel pump from a Twin Turbo Z32? those are supposed alternate from low and high voltage...any reason why this would not work?
I've also heard that Walbros are prone to breaking, though no one I know has had problems with theirs. Might not be a bad idea to check if it's still good or not...
Nismo1182
Car: Z06
Im running a walbro 255 on mine. The car does not throw black smoke out the back. It does run a little rich, but im guess thats due to the Mines tuned ecu. Plus the car does not want to keep a steady cruising pace. Im either going fast or slow. Theres no in between. The car starts to "studder" when i try to keep a constant speed. Like its misfiring or something. But I can free rev it and its perfectly normal. It only does it under load/driving.
If I step on the gas a little bit more it goes away. I also recently checked my spark plugs, and they come out black every time.
Some one said the KA -T and SR's have no problem with this. And upon further inspection of the site slw240sx posted, it seems theres a relay that controls this feature and that harness would replace this relay.
Well it got me thinking, maybe this feature is specific to the JDM model with all the JDM wiring. Maybe the KA-T and SR's dont experience this because they use the wiring from here (USA).
Maybe there is no voltage control relay for the US models? Can anyone verify this?
My car idles smooth and runs perfect under boost. Its just the cruising part im having problems with.
slw240sx
nismo, i think you might have a vacumn problemn or you are running a little lean at crusiing i too have the hesitation and when i adjusted my idle mixture to a little more rich it went away
Nismo1182
Car: Z06
slw240sx wrote:nismo, i think you might have a vacumn problemn or you are running a little lean at crusiing i too have the hesitation and when i adjusted my idle mixture to a little more rich it went away
adjust the idle mixture at the intake manifold? what about the adjustment screw on the MAF?
slw240sx
yeah thats where iadjust it from
Nismo1182
Car: Z06
at the MAF? if its at the MAF, which way do i turn the screw?
same goes for the manifold?
