C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Mar 10, 2004 12:56 pm
If it was coolant, the smoke would smell like coolant and have a humid feel to it. If not, it's likely oil. Valve stem seals tend to "cry" oil. At higher revs, it is diluted within the exhaust gases so much, it is not really visible. At idle, it tend to leak down, pool at the lowest point and then as it heats to an evaporative temperature, it turns into a vapor. Which is the white smoke you see. Turbine shaft leaks tend to be more constant and perhaps more apparent during higher RPM's where oil pressure is higher.
