carlos_knology »
https://forums.nicoclub.com/carlos-knology-u278.html
Wed Feb 12, 2003 5:03 pm
I realized I never posted an update about this issue. It turned out that somehow, the motor and regulator were stuck.
I went through the service manual diagnostics (to rule out any electrical gremlins) and at the end, it looked like the regulator or motor were the issue.
It was a pain to get the regulator out because the window would NOT move down no matter what I tried. With the regulator out of the door, I connected the wire harness and hit the window switch and NOTHING happened.
I thought the motor was dead. Removed the 3 screws that attach the motor to the regulator and that's when I noticed the two would no come apart. Pried them lose but it struck me as odd because when I replaced this window motor before, the motor just fell out after removing the 3 screws.
I decided to try powering the motor now that it was separated from the window regulator. Lo and behold, the thing worked. I can't explain why the motor and regulator were "stuck" like that.
After putting everything back together, it's worked fine since. Go figure.
Carlos
