Sometime my I35 doesn't start on the first crank
Jiggaman_I35
Car: Infiniti I35
aeMy 04 I35 doesn't always start when I try to crank the engine, it eventually fires up but after 2-4 trys, there is no code that come up according to the dealer they said its relating to my fuel.... i have done a fuel injection clean, it helped for a while but the problem is back ......... any suggestion on how to fix this problem would be helpful
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Fuel system would be my first guess, too.Does the car run okay once it's started?Do you ever hear a humming/buzzing sound coming from the rear of the car? That could indicate a failing fuel pump.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Make sure the fuse to the fuel pump is plugged in well in the fuse box and is not partially blown
Jiggaman_I35
Car: Infiniti I35
thanks for the reply i had to go to the dealer to get it fixed .........the problem was solved by them cleaning the carbs out and reseting the engine idle control to the original specs with there computer...... i bought the car used and this problem start about a month into having the car maybe this car had the problem before, and the dealer just quick fixed it. It costed me about $200 for them to fix it and it runs more efficent then ever... other than that the car is running great.....and my front bearings just went
