Something wrong with passenger window
Nissan 350z / Nissan 370z general community discussion forum
1stoptuner
Car: Nissan 350Z Touring
I always have to trick it everytime I want to close it. I have to shut the door while holding the switch. Otherwise it won't close if i just press the switch. I have to do this everytime i close my window. Some guy told me it could be the module.
cuffuup28
Car: 2007 Nissan 350Z
Try this: 1. Turn your car key to the ON position and press and hold the button to move your window all the way down and when it reaches the bottom hold for 2-3 seconds. Then press up and hold it as it goes up and then when it seals hold it for 5-6 seconds. If that does not work 2. Remove your door trim panel and where the motor is located there should be a small rubber nipple/button poking out. Roll your window all the way down and hold the button for 3-5 secs. Then roll your window all the way up and while holding the Window up button press and hold the nipple/button for 3-5 seconds.
Hopefully this works becasuse both these techniques have worked when I have fixed Altimas, Maximas, 350Z'z, Versa's and Sentra's and Murano's
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
It's fairly common on ther 03-04 Z's . The limits just need to be reset. Happened to mine. If you have connections at the dealership they fix it for free. It takes like 5 mins.
Return to “350z / 370z Discussion”
