Something wrong with my rotor or brake pad!~ help!!
S14-84
My brake pad was running out so my buddy and i changed it but now it starts to make all kinds of weird noise!!~ like bird humming nose or metal scrapping kind of noise!!~ First i thought it was normal but it turns out to be scrapping the top of the rotor!~ I took some pictures with my phone (kind of bad quality pictures). I ddint had my digital camera so yeah.
thanks guys
S14-84
More pictures
S14-84
One more
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
front or rear? id check and make sure you have your metal clips in there correctly.... also if you didnt turn the rotrs when you put on pads that could cause a noise
S14-84
This is rear...well those are new rotor as well too!! i decided to get new rotor with new pad but now its doing that!!~ i will check up on the metal clips
Juujai
looks like your rotor is warping. did you torque your lug nuts properly? what type of pads are you running?
sleepyRPS13
Car: to sleep
adjustments... did he backed & aligned the piston to the marks on the pads?also even if the rotor new there can be still out of roundness, was it ever machined?
S14-84
not sure but im gonna check it out tomorrow!!~ hopefully i can get it fix
boon240
Car: 1990 Nissan 240sx
sorry to bring this up but now i have the same prob. can someone help me fix this. i check my rotor and it has the same scrapping noise. can you tell me how you fix yours? thanks
i didn't know this was in 240sx section. can someone move it because i don't want to start a new thread. thanks
574-240sx
Car: Nissans, Toyotas, Subaru
Did he reuse and put the original brake shims back in. Those really help reduce noise and vibration. Did you clean the rotors and make sure there wasn't any grease or coating on them before installing.
0wn3r
Car: 1997 Nissan 240sx SE track car (SR20DET, caged)
I put X/S rotors and new pads on mine not too long ago. Make sure the dust boot isn't touching the new fatter rotors, you can just bend it away from the rotors but make sure you do it evenly and just pull it away a little bit.
If there is still a squeal, it could be that you don't have your shims... i dont have mine and i've only witnessed a squeal once or twice braking slightly at like 1mph.
I have a 97 240sx se, don't know what year you have, but you should have the pins 2 pins for each front caliper. And at least for my car, make sure that you turned the rear piston clockwise with needle-nose pliers or something to set it and don't just C-Clamp it in like you can with the fronts.
just some suggestions... good luck
[edit:] oh, looked at the blurry pics again and realized they were solid which leads me to believe they are your rears.
Modified by 0wn3r at 8:01 PM 9/27/2005
vvaffle
Car: 1991 240sx base hatch, 2009 WRX
I had a similar problem, turns out something got stuck in between the piston and the pad.Can someone explain to me what turning the rotors is and why it is done? Also, when you guys torque your lug nuts, do you do it while the tire is on the ground or in air?
Dattebayo
You should turn brand-new rotors when you install them... The pads drag on the surface if you dont.
Turning the rotors is also called "grinding" them. The surface of the rotor is ground down to make it have a more uniform surface, allowing your brakes to last longer and hold better.
