isnt the turbo creating suction toward the turbo? how would it pop off? or was it off throttle shuttering issues?themadscientist wrote:I was blowing through my AFM once and in the middle of a run I heard a "pop" and the car fell flat on it's face. I though I had done some kind of damage but it idled fine, revved no problem I got out and popped the hood. The incoming pipe blew off the AFM and it was just dangling there. I had gone from turbo to NA at 100MPH
Hmmm, i checked the wastegate.The actuator was secure to the gate.I will check it again.ca18detgabby wrote:I would check and make sure the W/G is nice and secure.
Ok,thanks for the hint.Is there a special way i should test it?float_6969 wrote:It sounds like an ignition problem to me. Check your ignitor.
he had it setup blowthrough style. which means he had it on his charge pipe, most likely cold side.ca18detgabby wrote:
if he had a wastegate issue, unless his flapper was wide open (which im sure you would notice by sound) it wouldnt just fall on its face like he is describing.ca18detgabby wrote:I would check and make sure the W/G is nice and secure.
Make sure the turbo is still spinning, too. Sounds like air to AFM issues or even the wiring to the AFM. Check the codes on your ecu since you've appeared to have done everything else.karism wrote:So I was driving home last night from work , and something went wrong.
I was going around a bend doing 45mph in 3rd gear, boost gauge was reading 3PSI .The engine lost power all of a sudden. It didn’t die, and was still running, although it wouldn’t boost.I didnt drive it hard at all on my trip home
I looked at the gauges, and noted the following: Water temp was in the middle (normal temps) ,I had ¼ tank of gas, no warning lights were on. Ambient temp was about 65deg F.I stopped and opened the bonnet. All of the boost pipes were nice and secure. The CAS wiring was plugged in securely, as were all of the other sensors. I couldn’t check the fuel injector plugs, as I would burnt my hands to crap.BMC cone filter intact, and sealing properly. No oil/water in the engine bay. Engine bay was also normal temps ,and didn’t smell funny
I started the engine, and it idled like normal, no funny sounds, or smoke from the exhaust.
I was drivable in vacuum. As soon as it would edge towards ‘0’ on the gauge it would start spluttering. The turbo just wont start boosting. I didn’t attempt to keep my foot flat and see what happens, but i`am pretty sure it wont boost even at WOT
The engine has about 3000 on since being overhauled.
Specs as follows :Ca18DET. 10:1 Compression ratio , Stock T25 turbo, and intercooler. Boosting 10PSI (normally) Custom exhaust, BMC cone filter.BCPR7ES plugs,1600 miles on them. Oil is clean, and not mucky
Any ideas to what I can look for ?
karis
I do it with the flapper door type but not the hot wire one. The flapper door can be adjusted with simple spring tension settings, is made of metal and does not have a fragile sensor doing the work in the hot oily air stream. The plastic hot wire AFM is fragile both in the the casing and in the sensor itself, bad juju.r34 gtr wrote:Blow through MAF = Win. I really don't see why everyone doesn't run theirs that way.
prolly was a loose pipe somehwere, one that you couldnt see. happened to me for a week.. i thought my car was dying (which happened later anyway ) but it ended up being a charge pipe that was only half on, but it was still 'tight' feeling, so i didnt notice it being open on the other side.karism wrote:Good Morning Guys.
I took off all of the boost pipes again,en checked them.
Rechecked the ignitor.
Took of the Intake pipe,and had a decent look at the turbo.None of the blades are damaged,and it turns freely.No metal shavings or anything I allso saw that i`am not running the factory turbo anymore!I have a replacement T25,it has a different trim to normal,but iam not sure of the specs
I checked the injector plugs,they were all nice and secure.
I tried firing it up.Started instantly.
I let it warm up a bit,and drove it to the garage (filling station) filled some gas
I drove it back again. BY George! Its boosting!!!!smooth and happy like before.
So,its running fine again,but i have no idea what was wrong ??
Thanks for all the suggestions!
karis
karis
