something weird with my car
kenversusryu
so today i realized something really weird while driving on the highway.
So i'm driving down the freeway going straight. My foot is on the gas on cruising speed and the steering wheel points a little right. When i lifted my foot off the gas.. the wheel is straight.. I gas it once again and it feels like the right rear wheel is pushing the car more than the left rear wheel so i have to compensate by pointing the steering a little to the right.
I know that the left rear wheel is at least pushing the car because if the right wheel was just spinning it would just be driving very very awkward.
Ive got a 2 way lsd and had an alignment 2 months ago. I have more camber on the right side than on the left rear and the inside is a little. Tires are pretty bad on the both rear too.
What could it be? Maybe i'll run the wheels on jackstands and see if both rear
NISTECH
model?
kenversusryu
95 240sx SE manual
stock rimsTein Flex CoiloverEBay Rear upper camber arms-1 camber rear left-1.5 camber rear right
I hope that helps
I haven't check tire pressure either but i really doubt that's it.
I also put in some pennzoil gear fluid in my lsd about 4 months ago instead of the suggested Kaaz fluid.
I doubt any of the above is the cause. Maybe it's just the left rear tires are worn? But both seem to be about the same and the right has more inside wear than the left.
Help me nistech! is it my diff?
NISTECH
Check your mount bsuhings in the rear both on the subframe and at the rear control arms. Sounds like a bushing might have given up. in a static state on an alignment rack all will look fine but when accelerating something is shifting in the rear.
