Something strange going on...
patrickm1587
Car: 1990 240sx- SR20 swap and a turbo that's absolutely too big, spools around 4,400 and I love it!!!
I've got a 1990 240sx, just got a SR20 red top swapped into it a couple of days ago and got it running. It runs fine, there's nothing wrong with the way it runs, but there's something weird going on in the rearend. I don't know if the mount is broke or if it's actually in the differential. When I put it in reverse and let out on the clutch, it will pop in the rear. It won't do it when you put it in first and let out on the clutch though. Anybody got any ideas? I know the previous owners could have tore up the rearend since it had a different SR in it, but is there anything I can check? Drop it down and take off the cover?
Edit:
If it turns out to be the differential, what can I swap in there besides a stock diff?
patrickm1587
Seriously? Nobody has any thoughts or ideas at all?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
A 95+ j30 rear end will give you a VLSD
Google is your best friend
Gabes13
Car: rb20det s13
Check the bushings before you do anything mechanical.
Hoffman5982
Car: '95 sr20det 240sx
j30 would prbably be easiest to find if you're near a junkyard. 95+ will bolt in, 94 and below require the axles. and for the s13 you'll need the cover off your old dif
patrickm1587
What is a J-30? I'm thinking it's bushings or something like that. Does it have a rear end mount or is it just bushings?
Michaelmoore
Car: '91 Hatch
Infiniti J30
jazz4890
Car: 1991 Nissan 240sx
A j30 is a differential from an infinity j30 car. That car has a differential that makes both tires spin together instead of the differential you have now that only lets one tire spin using the engines power. You should go to the junkyard and get that differential if your old one is worn out. As for the noise your car makes when you put it in reverse I have the same problem and I don't know what it is either. But it doesn't seem to affect driving in any way.
costa_rican13
Car: 1993 s13 coupe
I have a weird sound too but I also have the j30 diff as well..
patrickm1587
jazz4890 wrote:A j30 is a differential from an infinity j30 car. That car has a differential that makes both tires spin together instead of the differential you have now that only lets one tire spin using the engines power. You should go to the junkyard and get that differential if your old one is worn out. As for the noise your car makes when you put it in reverse I have the same problem and I don't know what it is either. But it doesn't seem to affect driving in any way.
Yeah I know, it's a LSD lol. I don't know if it's the diff. that's wore out or what, but it doesn't seem to affect the driving on mine either. It's got to be bushings or something.
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Well you have an S13, so check to see if the differential you have in has bushings on the front two bolts holding UP the differential. If it does, then it is those. I swapped differentials and had to knock those out and put washers on top and bottom to hold it in place. S13 don't use any sort of differential bushings.
Oh yeah and it make that weird "clunk" noise.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Get alu bushings for the diff. I plan on it whenever I'm going to mess with my diff next time.
costa_rican13
Car: 1993 s13 coupe
stance bushings for the win!!
