Something really weird...
NICONick
Car: 1993 S13
OK, so I was driving over to my gf's house after work and on the way there my car started acting weird. It almost seemed as I was in too high of a gear for the speed I was going but that wasn't the case. So, I downshifted anyways... it was ok for a few hundred feet and then I started to get nothing when i was hitting the gas pedal. No acceleration, nothing, and then it just died. Tried to start it again and nothing... It cranks and almost wants to start but doesn't... (Fuel pump was just replaced maybe 4-5mo. ago) Any ideas?
ash16847
Car: 1989 240sx hatchback
1991 240sx hatchback
What was your engine temp gauge reading? sounds like when I blew the head gasket on my turbo 240 a few weeks ago... unfortunately I didn't have a working gauge, so I am now saving for a new head as well.. FML...
NICONick
Car: 1993 S13
ash16847 wrote:What was your engine temp gauge reading? sounds like when I blew the head gasket on my turbo 240 a few weeks ago... unfortunately I didn't have a working gauge, so I am now saving for a new head as well.. FML...
Temp gauge read fine, lil below halfway.
I was also get some nasty timing chain rattle at the time...
EnjoiNismo
Car: 93 240sx
I had the same problem twice, car just died on me.
First one was alternator took a crap.
Second was the fuel pump, but just the fuel pump fuse.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Check fuel filter, fuel pressure, and for spark. Timing chain noise, you may want to put the motor to top dead center and check the cams (incase it jumped a tooth)
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
Mine was doing this and it was the MAF. Try unhooking it and see if it will run in safe mode (won't go over like 2-3k RPM. Also I tried sending you a PM NIck and you do not have them enabled. email is [email protected]
rsmithdrift
Car: 1993 240sx fastback se.
+1 on the fuel pump fuse.
I had this Exact same thing happen to me about a month ago. I had a bad battery terminal and it suddenly decided to start blowing fuel pump fuses every 50 miles. (the red connector on the + battery terminal with two plugs in it is for fuel pump etc) Everytime the fuse blows this same thing will happen. Slow fuel preassure loss till finally thier is none and car dies/wont restart. New battery and new terminals (factory ones suck nuts) solved the fuse blowing problem for me.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Check yo alternator son!
Razi
Car: Moo
Can you hear your fuel pump turn on when you put the key to 'ON'? (Don't start it though.)
I once blew my fuel pump fuse on the freeway a week after I went KA-T, scared the heck outta me.
It acted a bit weird and died like you describe.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
here is what you do:
go to your house, gf's house, gas station, etc.
get/purchase a gas can
fill it up
empty contents into fuel tank of 240sx
start car
drive places
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
lol
NICONick
Car: 1993 S13
EnjoiNismo wrote:I had the same problem twice, car just died on me.
Im thinking it might be the fuel pump fuse... where is that located? Under the hood or in the kick panel? Is it one where you can tell its blown or is it a big guy?
r34 gtr wrote:here is what you do:
fill it up
start car
drive places
wait.... wat? one more time... after i fill up gas can... then wat?
EDIT** OK, so I checked the fuel pump fuse (15amp) and it was fine. I also hear the fuel pumo hum before start up so I know it's working. I also have a 1/4 tank of gas ;)
Help?
Morph
Car: 91 Sr Powered Coupe
Unplug maf?
Check compression?
ILoveMyRHS13
ILoveMyRHS13 wrote:Check yo alternator son!
Mine did the same thing.
Check your alternatorrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.
Brent.S13
Car: 1995 Coupe- Totaled
1991 Hatch- Current
Yeah, my zenki did the same thing. It was the alternator. Check it bro, you'd be surprised. xD
NICONick
Car: 1993 S13
Well I was getting some nasty timing chain noise so I decided to inspect that route... took off the valve cover, dizzy, and front timing chain cover... I didn't like what I saw... Upper tensioner was bad, broke my upper and lower guides. The guides were in pieces when I looked in there...
Anyway... put the motor to TDC and it showed that the timing was off slightly... must've jumped a tooth :(
Oh well... Timing Kit? or New Motor?
alms24sebring
'04 Nissan Sentra SER SpecV
dam. People rebuild KA's and sell them for $250 to $500 depending on parts and work done.
truepinoy
Car: 240sx 1990
You should do it yourself, it'll be a learning experience. My car doesn't like to be touched by other mechanics, only me....o yeahhh
NICONick
Car: 1993 S13
alms24sebring wrote:dam. People rebuild KA's and sell them for $250 to $500 depending on parts and work done.
Oh ya? Care to share your source? Love to get a built or lower mileage one for that.....
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Most KA's around me are $300-500 and not rebuilt, although these engine's can easily go to 200k without a rebuild if not abused so most of them are good.
rsmithdrift
Dude your engine is fine... if you didn't get valve interference then nothing is damaged. And I know from experience you have to be off atleast two teeth to get interference.. don't ask. It's a HORRIBLE sound too. You would know.
You just need to fix the tensioner and retime it. Problem solved.
BCNR13-specD
Car: 1985 mercedes 380se
have you ever been to a 1/4 tank? maybe 1/4 on the gauge is 0 in tha tank. also when the pump was replaced dirt could have goten into the tank cloging lines pickup screen filters ect.
