SD CONCEPTS wrote:I love the critisism, but what are some questions you have and what do you think the advantages and disadvantages are
It's very unconventional. That's one thing for sure. I am sure you are more comfortable with the distributor and maybe you can fill in why you chose it.
The only disadvantage I would see would be you lose digital ignition control which uses other sensors as a feedback of when to ignite, as well as a fail safe retard timing when the engine begins to knock. If we could process things as fast as the PCM/ECU the engine would look like it's hardly moving at all (but to our human eyes it's reving 6k rpm). With that it's a very powerful tool to let it control ignition timing in order to make sure your engine is safer from that random poor quality fuel tank, lets you run lower octane and even run higher compression ratio due to being safeguarded.
But above isn't necessary if you aren't demanding higher HP figures or high rpms.
Please enlighten us.
