something its burning my ignition coil on280zx 1980
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
rulaznetro
Car: 1980 280zx
HI guys any idea of what could be the problem?
my nissan 280 zx 1980 its burning my ignition coil causing not sparks, already put all the ignition system new: distrubutor with a ICM and rotor and cap, also spark wires and coil is new, but still heating to much the ignition coil, if i run the car for 30 minutes coil its going to be burned.
wen car its runing on the positive side of the coil its 12 volts present and in the negative side its 10 to 10.5 volts, tachometer seems like its working fine, also there is two wires close to the ignition coil but nothing its conected there i wondering if this model 1980 still using resistor.
also if i replace the coil for a solid coil, can any of you tell me if that could work?
thanks in advance.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Sounds like you either have a 6 volt coil, bad coil, either way, replace the coil.
rulaznetro
Car: 1980 280zx
Hi Rusty.
I did it 2 times the one is installed right now its a 12vdc coil.
Return to “Datsun Z Forum”
