Something is bad wrong!!
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
sarahnicole2339
Car: 2005 Infiniti Qx56
Hey everyone!! I'm new to the site and I'm having some problems with my 2005 qx56. It started with the smell of rotten eggs coming out of the air vents today. When I opened the hood, the smell was coming from the battery. So I went to crank it and it had a bad hesitation but it did crank after a few seconds. I put it in drive and when I pressed the gas it did nothing. When in reverse it backed up but nothing in drive or any other gear. I'm thinking the battery is being overcharged by the alternator but I don't know. If anyone has any idea, please help!! Thanks!!
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
If you are not confident about putting an ammeter on the altenator to check voltage output, you should take it to an auto electrician.
They will be able to check this for you. It may be that the battery is to blame, and not the altenator.
Typically, a rotten egg smell indicates that your exhaust may have a leak and/or that the catalytic converter is no good.
Do you have a check engine warning light on the dash?
sarahnicole2339
The check engine light isn't on. Put a new battery in last night and it seems to be fine right now. I am getting the alternator checked right now. Fingers crossed it was just the battery. And the bad smell is gone!!
sarahnicole2339
The guy said everything passed so hopefully it was just the battery and nothing else.
Ozzie
'06 MK5 Golf tdi
Cheap easy fixes are always the best. Glad to hear everything is running ok now.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
