szh »
https://forums.nicoclub.com/szh-u149.html
Tue Feb 13, 2007 9:28 am
Your window regulator has probably broken, I think (probably not the motor). This was a common problem in the first-gen Q45 ... I lost all four over time.
Two were replaced under warranty, and two were paid for by Infiniti Corporate because I considered it a design flaw and insisted on it! Might be a bit late to be considered a warranty change in your case (which year Q45 do you have?)
The part is relatively inexpensive and if you can take the side panels off, then you should be able to see the part that has broken and get it replaced.
Z
