thats what Im saying. the bin for my #98 ecu has values of 26, which for ca18:26-16=10deggood morning wrote:If your bin is at 10*, you want to sync that up with mechincal timing.
Just make the ECU is locked at that degree and not adding timing.....
You are right. It is just base timing. The other people are just passing on info is wrong or see it different.Nunook wrote:
the UK tune that I had gotten from Norris designs had 31 meaning:31-16=15deg. Also the stock UK bin (I dont know what # ecu) is also 31.
This is for base timing. Once u put the car in gear, it switches to the timing map.
