something electrically toasted?
Type X(J)
Car: '98 240SX SE
hey guys, just wanted to ask your opinion about somthing.ok, so this is my situation:I got my car('89 hatch) back from my mechanic two days ago(just did clutch swap) and I drove it for about a mile going home.yesterday, I tried stating it and it didn't start. There's a clicking sound but nothing else. I looked under the hood to check and saw that the batterries negative tip had some molten stuff on it, looked on the hood and saw burn marks on the area that would usually be on tp of the negative side of the battery...so I'm guessing I shorted something...or worse, fried my computer.
can someone tell me what kind of damage i'm lookin' at. ThanksArch:confused:
ninjak84
Car: S13, Z32, Titan
The clicking sound is 100% your starter.Sometimes, if you tap the starter housing with a hammer or something, it will start, but eventually it will just die. I suggest getting it repaired ASAP. I had the exact same problem in my 92 240sx. Let me guess, when you turn the key, your dash lights still glow? That means your battery is still fine.Therefore, it's the starter :)
Type X(J)
Car: '98 240SX SE
thanks for u'r reply.the dash light does still light-up.I'll try to make my starter work thanks for the infoi'll posts again and let you know what happens
Type X(J)
Car: '98 240SX SE
my cars running again!!!it turns out that i only had to replace the top post terminal (positive side).i also cleaned off the acid residue on each terminal.all's good.
