"During 1995, 25 percent of all gasoline consumed in the United States was reformulated, rising to 32 percent in 1997. Because the additives contained in reformulated gasoline have much lower carbon shares than typical gasoline, the national average emissions coefficient for motor gasoline has declined by about 0.25 percent over the past 3 years (Table B1). At the same time, the heat content of gasoline additives is lower than that of standard gasoline. Thus, an average gallon of gasoline sold today has a lower energy content than an average gallon sold 4 years ago. Holding car weight, horsepower, and miles traveled constant will require increased consumption of gasoline."
"By the summer of 1996, most reformulated gasoline no longer contained any tertiary amyl methyl ether (TAME) or any ethyl tertiary butyl ether (ETBE). Nearly all additive used in reformulated gasoline was MTBE, the additive with the lowest emissions coefficient (Table B3). "
"ALCOHOL % IN GASOLINE TEST KIT:
We've had a number of calls from auto service technicians requesting help to test the gasoline in a car that may have been misfueled. Now that the EPA has mandated the substitution of ethanol for MTBE as the oxygenate, automotive technicians are faced with yet another diagnostic challenge. This kit will help determine if the alcohol content is the problem without having to send a fuel sample to a test lab. Kit includes :
• Easy to follow gasoline testing procedures
• Precision 50 ml Graduated Cylinder
• 150ml Sample beaker
• Fuel siphon.
• Safety Items, includes glasses & gloves. $39.95
http://www.ridgenet.net/~hideseng/prod0 ... es...r.htm
" As gasoline ages, it may lose some of the more volatile hydrocarbon components through evaporation or oxidation. 'Stale' gasoline can degrade performance, possibly cause costly engine damage, and may render the fuel illegal for use in competition. "
http://www.ridgenet.net/~hideseng/g-01.htm
List of racing fuel densities:
http://www.ridgenet.net/~hideseng/dc_list.htm
http://www.carrito.net/hp_calc.htm
The FIA's World Rally Championship is the easiest to describe: Shell is the current fuel supplier. Priority drivers (i.e., the top guns) must use this 95-octane unleaded gasoline. Lesser ranks can get their fuel at commercial gasoline stations noted in the route book. Fuel characteristics and refueling strategies are far down the list of why WRC is so exciting.
Sports-car venues also depend on organizer-supplied unleaded gasoline. Octanes vary from venue to venue, but the official Sunoco Unleaded GT100 of IMSA's GT3 Cup Challenge is typical. It's a street-legal gasoline, with Research Octane Number of 105 and Motor Octane Number of 95 yielding its Antiknock Index, (R+M)/2, of 100. This gasoline's density, its specific gravity, is 0.764. That is, it's a tad more than 76 percent the density of water, roughly midrange for gasolines cited in the Bosch Automotive Handbook"He and other NASCAR engine specialists will continue to rev 358-cu.-in. ohv V-8s beyond 9000 rpm, and do it for hundreds of miles of racing. They'll continue to use Sunoco Supreme Leaded (RON 114, MON 110; specific gravity 0.715; like 100LL, blue in color).
The ONE IMPORTANT THING TO NOTICE IS THE CONSTANT REFERAL TO MON!
Notice these fuels range 95 to 110 vs pump gasoline which may be BELOW 85!
