Somethin is allll messed up.
Post all your Nissan electronics, car audio and stereo questions here!
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
Alright, I've got a Kenwood KAC-5203 head, alpine speakers all around, a Kicker amp, and 2 hifonics 12's..
I have no idea what the problem is, but whenever I try to use the stereo, it will work for about 15 seconds, and then just reset, and keep reseting, and not work till I shut it off for a while, and then it will repeat the process.
I've checked all my head unit wires and they are all connected fine. The power/ground/remote wires are all connected fine. What could my problem be? I can't even listen to my stereo now. :\
EDIT: Some more info on it. I unhooked my amp and subs and it still does the problem, but I noticed it only does the problem at a certain position that the key is turned.
I put key in, turn it one notch and the dash clock lights up a bit, and the stereo turns on. At this point, everything will work fine. When I go one more notch, right before turning engine on, and all the dash lights are red, this is where it just keeps reseting.
Also, when I get around volume 20, the music kind of distorts when the bass hits.
I'm running 4 gauge wires and they are efhin big, hardly and don't even really fit into the amp.
Please any help would be great.
Modified by Two Fowty at 6:12 PM 4/23/2009
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
If it works fine in acc but not in run then it sounds like you have a bad ignition switch.
w8lifter21
Car: '91 300zx TT, 99' Honda Accord
Do the symptoms come up while the car is running?
