Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Mon Nov 22, 2004 11:29 am
Ok, the first picture, that's a vacuum port for your carbon canister, which is the second picture. What you want to do is get a vacuum line from the vacuum port in picture one to the nipple in picture two. For the last picture, the Y connector there, the end with the larger hose, that goes into the intake piping before the throttle body. There should be a nipple (if it isn't broken off) in the bend right before the throttle body. That plugs into that. Hope this helps. Good luck!
