someone with a t25 and how it goes?
Rusty 240
Car: 2x s13
like the question said i want to know if the the turbo t25 is good turbo for the ka24det setup. i want a standard setup near 250 hp. thanks
kamikazestorm420
what kind of fuel/timin r u going to be using?
hannibal
Car: Red Line to Glenmont
The T25 is generally thought to be too small for the KA, although some have used it with good results.CHeck out this thread...http://www.nicoclub.com/zerothread?id=92455
Rusty 240
Car: 2x s13
maxima mss air flow, 370cc inj, walbro 255 l\hr good reprogramming ecu by someone who does that around here.
kamikazestorm420
it willbe really hard to get 250whp with a t25.
with stock boost u r looking about 200-210 to the ground maybe.
maybe if you boost about 1 bar you will probably get around that number but 1 bar on a t25 i heard is pushin the turbo ..especially on the ka.
Rusty 240
Car: 2x s13
his your setup and engine are reliables since you're turbo. and how do you like the power difference from the stock motor?
SoCalSilvia
Car: S14- 1995 240sx
with the SR t25, it would be easier to find all the turbo accessories like downpipe, intercooler piping, intake piping and all that stuff right? Since you can use the massive amounts of SR aftermarket parts that are out there right? Like you can use a stock SR smic, a megan racing downpipe for SR, and a arc intake box for SR right?
drifts14x
Car: Cars, Motorcycles, Drifting
you can use most of those parts, but do remember, the turbo will be in a different place than it would be attached to a SR20DET, so yes, the SMIC and piping would work, but will still need some custom work for adaptation. The Intake box, would work to, again, with modification, so keep all of that in mind.
Rusty 240
Car: 2x s13
and what about a t28 from a pulsar gti-r? find a deal on one.
SloMoe
Car: Fast Cars, Music, Girls
drifts14x wrote:you can use most of those parts, but do remember, the turbo will be in a different place than it would be attached to a SR20DET, so yes, the SMIC and piping would work, but will still need some custom work for adaptation. The Intake box, would work to, again, with modification, so keep all of that in mind.
Wasabi Garage makes a bottom mount KADE turbo manifold with a T25 flange on it that places the turbo in the same location as the SR. SR downpipes and exhausts should bolt right up, as well as the hot side of SR intercooler kits. You would need to have a custom cold pipe made for the intercooler though so it lines up with the KA throttle body.
hannibal
According to RMiller and other guys, the GTiR T28 is the best small turbo, maybe even better than the Z31 T3.
Fenvy
Car: 2005 350Z Base 6MT
t25: turbo lag of death
SoCalSilvia
thanks for the heads up
Modified by SoCalSilvia at 4:56 PM 1/7/2005
Toahk
Car: 97 ....
I used the sr sidemount with all the piping, I just had to extend it with 2.5" exhaust tubing to reach the TB on my single cam.
Oh btw this is used with a z31 t3 turbo.
SoCalSilvia
Toahk wrote:I used the sr sidemount with all the piping, I just had to extend it with 2.5" exhaust tubing to reach the TB on my single cam.
how much power are you putting down? what kind of fuel setup? SR injectors with SAFC?
BadMojo
Car: 2007 Mazdaspeed 3
Loveless wrote:t25: turbo lag of death
Turbo lag on a 2.4L KA engine with a T25? I'd think that little sucker would spool up like crazy, turn in to a heat pump and fall flat on it's face over 5K.
Fenvy
i didn't read, mine is on a sr20det
kamikazestorm420
if you use a t25 on a ka, you will get full spool at about .. maybe 2800 rpm.
it is more than enough power to daily drive on the streets and auto-x
Toahk
Car: 97 ....
SoCalSilvia wrote:how much power are you putting down? what kind of fuel setup? SR injectors with SAFC?
I dont know how much power, never dyno'd it. Fuel setup is 460cc injectors with safc. Cant use SR injectors with the single cam because they are side feed.
