ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Mar 16, 2003 11:45 pm
ok... try this: says to disconnect the plug to the sensor to fool the ECU & crank the engine.. if NG, check the circuit.
1st thing to check was battery voltage: less than 12V in the morning, charge/load test the battery. it seems that the tach reading should be about 300rpms when cranking.
another may be the starter operating too slow
other check is to see if the Air regulator stays open before warm-up
