EnzoRWD »
https://forums.nicoclub.com/enzorwd-u3754.html
Sun Dec 14, 2003 5:16 pm
ok i got some info. nismo_freak: i was worried about that. i think a smaller plenum and a tapered design might work well.that nice top one is a one-off made by kiwi. that explains the fancy design. the second one uses the stock runners, hacked down.if i shorten the runners, would i want a plenum/chamber at all? im thinking possibly using a 3" dia tube design, tapered, mated to stock runners w/ extensions. ok, to clarify, cut stock runners short to use stock mounting and fuel rail./injectors. add to those runners extension making nice 8" runner <ill do my best to match the ports and bore the stock piece out a bit> at the end of these have a smallish tapered tank, with a stock <?> tb at the front.-Enzo
