ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sat May 08, 2004 4:03 pm
hook up your fuel pressure gauge from the top of the gas filter to the metal fuel rail
when idling, the gauge should read around 33psi w/ vacuum hose still attached to FPG
disconnect that small vacuum hose from the fuel pressure regulator
see the gauge go up to ~43 psi
another way to check is w/ a vacuum pump (u prob can rent this tool for free @ autozone)
disconnect the vacuum hose from the intake manifold & cap the intake manifold
start engine
as vacuum increases, the fuel pressure should decrease
from my FSM, page EF & EC-154
if that check out ok, then do a trouble code reading; 1 cause is it may also be a bad temp sensor/circuit that's telling your pc to run open loop until car is warmed up...
