Powered Bya Skyline »
https://forums.nicoclub.com/powered-bya-skyline-u173821.html
Tue Feb 15, 2011 8:33 pm
well decent news, i did a smoke test to the manny and i found about 3 leaks, one from the nipple for the brake booster and the stock boost gauge nipple, along wth a small nipple under the throttle body that goes to the charcoal cansister that i dont have, and the pcv hose. i also blocked off the what i am guessing to be the cold start box? i could block off the iacv before and the car would stay running, once i blocked the other line off not so much. heres the werid thing after fixxing those problems i still had an above normal idle say around 23 to 2500 rpms on my doch tach. i know its higher than what it actually is but once i disconnect the iacv the idle drops to around 1k on the tach and it idles amazing, any ideas? maybe anther vacuum leak i missed?
