jaytv1019 »
https://forums.nicoclub.com/jaytv1019-u36806.html
Wed Mar 07, 2007 7:26 am
PLEASE do NOT take my word for it, I am just tossing some ideas around but...
I would focus more on the MAF situation. My stock MAF on my SR went out one day. No reason, just decided it was done working. The car would not fire up and if it did it would not stay running. The way that I checked to see if it was bad was you unplug the MAF and the car will start but in limp mode. You will be able to drive it but not really able to go above ~4K and it will idle higher. That is how I knew mine was bad.
You have a different but similar problem. You know your maf is good (or might not be anymore) but your plug could be the problem. They are very sensitive electronics and if there is ANY resistance in the wire it will cause havoc and inconsistant behavior (what you have)
If I were you, I would just upgrade right now to a Z32 maf, get one with a pigtail, that way you replace the plug and can eliminate that from the list of possible problems.
NEXT STEP
I would unplug the maf and see what happens when you try to start it.
Get back to us.
