someone please help..
latinQ45
i have a 1990 Q45 Transmission is giving me problems. The other day im driving down the highway and all of a sudden the RPM's go all the way up and doesnt shift no more. Then car slows down and thats it. So i can turn on the car and drive a certain distance but then the gears go out and cant drive are these the first steps of transmission failure if so how much is the fix thanks a lot.
Q45tech
Are you getting a " Transmission Malfunction" on Dash Diagnostic Information Display?
latinQ45
yes i started seeing that a couples hours before the car started going bad
Q45tech
Follow the detailed proceedure [in FSM] to have the display read out the code! It will display 14 different individual codes, some times multiple codes.
Best to take it to a dealer just for diagnosis! Because it could be a bad corroded connection. Then find a JDM [Japanese junkyard shipped to US] transmission down in El Monte. Avoid domestic junkyards as the mileage/abuse will be higher.
Takes 5-6 hours real time to swap carefully.
Another AMAZING helpful intervention by Dennis.
Thanks Tech!
RBYoshioka
Car: 1990 Infiniti Q 45a, with 227,000 miles. Third Owner.
Hello,
Am a newbie. Please furnish name, address, phone and email for the JDM place in El Monte where rebuilt transmissions might be available for purchase?
Thanks
Robert B. [email protected]
RBYoshioka
Hi! Did you ever get your problem resolved? I tried locating an new/used transmission someplace in Ontario, CA., and am still looking into dealing with this problem I also got code readings from doing a self-diagnostic. Have been told that it is possibly solenoids and that would be cheaper than having to deal with putting in a new transmission. What is the status of your situation? Best, Robert B. Yoshioka. [email protected]
