someone please help
S13 240SX
Car: 93 Mazda Miata
This is the second time i'm gonna post about this.. last time i got nothing.
my headlights don't work... new headlamps, new headlight switch, new relays, and new fuses. WHAT THE PISS IS WRONG? AND THE ALL THE WIRES AND THE PLUG THAT PLUG in the back back don't smell burnt.
S13 240SX
Car: 93 Mazda Miata
can anybody help me firgue this out? come on guys.. I help everyone else out here on the forums. lol i need the help now too. Or else officer pig noise is gonna give me a big fine if he sees me driving again at night but the problem is i get out of work every night at 6:00pm. lol
S13 240SX
Car: 93 Mazda Miata
wow okay thanks everybody for the no replies!!! yeah really gotta tell ya THANK YOU!.
mechcap
Car: 89 nissan 240 sx
i had a simular problem with my 89 coupe.i found the plugs on the positive battery cable were corroded.cut the plugs off and used terminal connectors to attach the cables .fixed my problem.need more info send email to [email protected]
S13 240SX
Car: 93 Mazda Miata
oh okay well that is not the problem for me,, all my **** is free of corroded. nothing is corrded on my car.
2projects2many
Car: '91 S13 SR20DET
Has there been any tinkering with wires(ie: sleepy eyes conversion)?I'm new to the 240, (just bought mine three weeks ago) so help me by telling me if the dimmer switch is also part of the headlight switch, multi-function switch, or is it seperate. If it's seperate check to see if the power is coming into it from headlight switch before the relay.
S13 240SX
Car: 93 Mazda Miata
my dimmer switch is working not sure if its built in with the headlight switch, but the headlight switch is brand new, and my dimmer works fine, the dime is not even low, and plus all my relays are getting power all relays work.
tiger
is there a possiblity that one of your wires may be cut or damaged? Trace your wiring.. it may take a while but just trace it and see! something could be loose.
S13 240SX
Car: 93 Mazda Miata
the only wire that is cut is the brown wire to make the lights sleepy eyes.. and it has been cut for years.
mr2lickit
Car: looking
It seems like you've done everything. All I can reccomend is make sure nothing is loose and check everything with a voltmeter, and if it still doesnt work then the only thing left is the wiring. Sorry about the bad luck
S13 240SX
Car: 93 Mazda Miata
well i pretty gave up for now.. I'm not checking all that damn **** with a volmeter its way too much time, and plus I was gonna take the car to nissan to have them find and fix the problem but they want 75 dollars an hour for labor and i'm like NO **** THAT!.
i MAY JUST DUCT TAPE REALLY POWERFUL LONG LASTING FLASHLIGHTS IN!!!
