BrittanyTN »
https://forums.nicoclub.com/brittanytn-u300454.html
Fri Feb 26, 2021 5:16 pm
Hey yall, first off, I'm a new member on here, so I just want to say thank you in advance for any help or advice on my issue I'm about to describe.
So I have an '08 Nissan pathfinder 4WD, about 3 days ago my service engine soon light came on, and nothing was really going on yet, then yesterday my SES light started flashing only when I would get above 2 RPM, then it would just stay illuminated when under 2rpm. It also has a pretty noticeable rough idle, and now today I noticed a "bog " down when I would try to accelerate.
So I got it scanned, and it threw codes P0305 ( cylinder 5 misfire) and code P0420( system efficiency below threshold bank 1) it was recommended that I replace my spark plugs, especially #5, so I purchased all 6 new spark plugs( NGK IX irreduim) changed them all out thinking it would fix my issue... HA, not even close, my SES is still on, still flashes when above 2rpm and still has rough idle. So I then switched my #5 ignition coil with #2 ( bc #2 is so much easier to get to) just in case it's the ignition coil.
What I'm needing advice with, has anyone else has a similar issue? Had the same codes thrown when scanned, and what was the solution to the problem? I'm just really not wanting to spend any extra unnecessary money if possible. I just really need my truck to be running correctly.
Thank you so much in advance for any advice or suggestions!!
