thanks in advance guys! i'm new to this forum
elwesso wrote:yikes... I would say you definitely have an alignment issue, the bottom line is you need to take it to an alignment shop and at the very least they need to read your current alignment so you can see where you are at... That will help out a lot...
are you talking about the clear white-ish clip thats on the paddle knob? so i should remove that and push in into the seat first then put the paddle knob over that ? the white/clear clip only has one side of the clip on it, the owner broke the other one. ...mrpeeb240 wrote:I have same issue with my passenger seat, if you have both the knob and the clip that goes into the seat you can carefully insert squre end of clip into opening on seat then place paddle knob on clip and work the recliner. Mine sits perfectly on the side of seat but will fall off if played with.
Brent
