Someone in or around Overland Park want to help me install some headers on a Z33
Including ND, SD, NE, KS, OK, MN, IA, MO, and WI
koolzero
Car: Nissan 350Z
Hi, I live in Overland Park and I just got some headers for my 350Z and I would like to know if anyone would be willing to help me install them?
I don't have the right tools or experience to install them and the prices i've been quoted from around Kansas City have been from 400 dollars to 700+
I would be willing to attempt installing them myself if I had someone there to help, I would even buy all the tools that I need to install them with.
So if anyone out there is willing to help me out, and or has a lift that would be excellent!
Attached is a comparison of stock headers to new headers.
blackx
Car: Stikfas
Did it come w/ everything like the gaskets? What brand is it? Have you heard of any fitment issues from anyone else that has installed the product or any issues after installing the product? Do you the torque specs?
If I help do I get to drive it after the installation..... aaron if you read this what do you think? Might just be worth my time if I can have a go w/ it.
koolzero
Car: Nissan 350Z
Everyone that has installed them has said there aren't any fitment issues. The brand is Top Speed they're basically a copy of the DC Sport headers. I was told to use the same gaskets that are already on the stock headers as the ones that came with them aren't any good to use. I also have to pick up some bolts to connect the end tube of the headers to the cats because the oem have bolts built in.
I can lookup torque specs but the people that sold them to me have said there isn't enough room to torque them to spec (but that doesn't make any sense to me). I also want to throw on some hi-flow cats and possible do some new pulleys. I wouldn't mind letting you drive it either, as long as you don't beat the piss out of it.
blackx
Car: Stikfas
koolzero wrote: I was told to use the same gaskets that are already on the stock headers as the ones that came with them aren't any good to use. .
I would at least buy new ones from nissan then..... Can you source the FSM or anyone else's walk through with any header on the 350z? I am sure there is a pattern for removing and reinstalling the the nuts that connect the header to the head.
Have you checked out freshalloy yet? Might want to check w/ the 350z owners there and get there opinion on not torquing down the bolts, that sounds a little off.
BTW im in olathe...
koolzero
Car: Nissan 350Z
Here is a pretty good walkthrough of how to install headers and high flow cats: http://www.zchickz.com/header1.htm and I've got a doc file that i will try and attach as well.
Another good website on how to install Nismo headershttp://www.350zforum.com/tech/....aspx (this one btw looks freaking complicated!!!)
And the attachment is how to install the Crawford Headers.
I was told from someone that has installed 2 sets of these headers on the Z that "if you use a extension then the torque numbers will be off" cause an extension was the only way to torque the bolts on the headers, he just said to make sure they're tight.
Modified by koolzero at 11:05 PM 12/7/2004
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Kevin, Jesse is a good guy, he gets my recommendation for helping:)
you guys might have met each other b4 at one of our old chicago after meets at Starbucks up on 119th and Metcalf... Jesse has the black S13 fastback with a ton of suspension and Kevin has the silver Z33 S-Tune with the c-west kit
ps, im so glad to see KC ppl helpin each other out
-Dan
koolzero
Car: Nissan 350Z
Blackx, have you had a chance to look over the directions? Let me know what you think.
ca18det_boy
jesse yeah I read this, personally I wouldn't touch a Z33 with a 20ft pole. Also getting the factory torque specs isn't that hard to do all you have to do is call nissan. You NEED to use new gaskets with the new manifold and I would check your source because they can't be a copy of DC headers. DC is the mainly for honda's. Shop time for the install is probly around 5-8 hours if not more and thats assuming that you have all the proper equipment in case something breaks...like exhaust studs. Yes, you can't use an extension because that will drastically change the torque specs that you're layin down. There is always enough room to torque things down and if anyone else says otherwise then they're not worth your time. The factory uses torque specs for a reason...its not a suggestion. Anyways enough of my ranting, point being Kool, best of luck to you and welcome to the board. I hope that you get these in without too much trouble. Jesse, yeah you might want to have a go with it but the engine bay is worse than a Z32 (thats my opinion.
If you two decide to go ahead and do it then I'll be around in case you need something but you do need to get new gaskets and 1-4 spare exhaust studs. You also DO need to torque everything back down to factory specs and in order. Don't have too much fun and I'll talk to you peeps later!
-Aaron
koolzero
Car: Nissan 350Z
If you don't believe that DC Sports makes headers for the 350Z then you should take a look here:
http://www.z1auto.com/prodmore...d=874a ... ..965cdand here:http://www.turbomagazine.com/tech/0409tur_zheader/
here is a link to the header install from the service manaul:http://koolzero.bounceme.net/manual/Em.pdf
And about the torque specs I've got the 350Z shop manual so torque specs aren't an issue. I'm just going on by what i was told as far as not torquing it down to spec.
Attached is a screen shot from the service manual.
koolzero
Car: Nissan 350Z
BTW here is a comparison of DC vs Top Speed
DC Sports
Top Speed at the bottom
koolzero
Car: Nissan 350Z
She's screaming for some headers!
(can't wait to see what my seibon hood's gonna look like)
ca18det_boy
WHOA there hoss, you don't need to get all upset at what I said. I said that DC MAINLY produces headers for hondas and that you might want to double check your sources. There isn't a need for you to get that upset. My friend asked my opinion and I gave it. If you don't like it then thats not my problem. Like I said welcome to the forum and it might be wise to act a little nicer and to not get so offended.
ca18det_boy
oh and one more thing, DC said that they just released them....forgive me I was wrong I can admit it. I just don't pay attention to people that manufacture honda parts.....
koolzero
Car: Nissan 350Z
ca18det_boy wrote:check your source because they can't be a copy of DC headers
ca18det_boy wrote:DC said that they just released them
I wasn't offended i was just pointing out that they do make them. They didn't just release them it was 7 months ago that they came out.
Modified by koolzero at 5:14 AM 12/10/2004
Dano
LOL @ all of you, geez, i leave for a couple months and you cant even help a homie install some headers, lol. I told Kevin i would help him over x-mas break, but if some1 like jesse or aaron (aaron, dont get pms'y bro, its just some headers ) would help Kevin out, that'd be awesome, i dont wanna spend my only week back home workin on cars the whole time... some1 do me a favor and help Kevin out? he's a cool guy
-Dan
keepingthe240
Theres a shop off noland road that can do the install in no time. They'd charge maybe $150. I'd like to get my parts (stacked in a corner) on my car. Guess i'm unloved or unwanted. You'll need to spray down the bolts a week before hand and you might need a propane torch if the bolts don't come undone. A car that new, it should come off easy.
ca18det_boy
according to DC's homepage they JUST released them. I was going off http://www.dcsports.com. I guess they're wrong.......
koolzero
Car: Nissan 350Z
Sideshowbob, what's the name of this shop that you speak of? If any shop would install these for only 150 that would be amazing!
Edit: Are you talking about Parallax Motorsports? I'll definitely give them a call.
Edit Edit: called the number on parallax website says the number is disconnected. Maybe they're out of bizness.
Modified by koolzero at 4:19 PM 12/10/2004
blackx
Car: Stikfas
If you can find a shop to do it that cheap then do that since they should have a lift which will save time.
If not then let me know by next wednesday and I will try to make time that sunday. This weekend I just have to much going on.
Im downloading the FSM off carfiche as we speak so I will get back to you if I see something im not comfortable with.
Do you have a pic of your engine bay? My neighbor has a base model 350z so I will see if I can see under his hood as well.
koolzero
Car: Nissan 350Z
Ok thanks man, but we don't have to do it anytime soon. I have yet to order some hi flow cats that i want to put on too with the headers. If need be it can wait until after the holidays so no rush just whenever would be the best for you. i can also post some pics of the engine bay. Whoa carfiche is a cool site i've never heard of it before!
Here is a link to the shop manual and Exhuast Manifolds: http://koolzero.bounceme.net/manual/Em.pdf
keepingthe240
Yea, thats the shop. I was up there a few months ago and talked to the guy for a few hours. He has a bunch of z32 engine stuff that sirus left up there. He was saying that he's had a few 240sx up there since he bought it from sirus. And yea, he is hard to get in touch with. But, he charges $30 an hour. His friends and customers that know what there doing, help with labor! He was saying to me that you can rent his lift for $45 a day. If you help with his stuff, he'll let you borrow it for free. Best time to borrow it might be on a sunday, when its closed. If the header is a direct bolt on and the car so new, you should be able to do it with ease. My hotshot header is another story. 1 year and its still not on. Save your self 150 and do it yourself!!
blackx
Car: Stikfas
Im game to do it then... let me know when you have the cats and all the gaskets we will set a date\time.
whats your email?
Dano
thanks for helpin Kevin out. When i get back after school is done ill whore myself out to help u guys get **** installed
-Dan
koolzero
Car: Nissan 350Z
Hey sideshow do you happen to know the number for parallax motorsports, the number on their site isn't working?
keepingthe240
It should be 836-2800 It took me 2 weeks to get though when i called him a month ago. The fax machine was anwsering each time. If not, drive up there on a saturday. THere is an autozone kinda by it. The shop is down a gravel road, kinda hard to find.
koolzero
Car: Nissan 350Z
blackx wrote:whats your email?
[email protected]
koolzero
Car: Nissan 350Z
What's your email?
blackx
Car: Stikfas
You should have got a email from me directing you to post on another site.
koolzero
Car: Nissan 350Z
Sorry, but I didn't see it, i get way too much junk mail at that account and I have my filter set at the highest setting. Send to this one instead: [email protected]
Modified by koolzero at 8:48 PM 12/16/2004
koolzero
Car: Nissan 350Z
Should be here before christmas. Jessee when would be a good time to try and do this? It looks like right now that the next weekend that I will have available will be January 8th - 9th.
I will also have a Seibon Carbon fiber hood and Nismo power steering oil cooler kit also to install at that time. I know this is probably too much to get done in one weekend and that's okay with me we can do it over a period of weeks if need be.
Modified by koolzero at 3:12 PM 12/17/2004
Return to “Midwest Region”
