I am getting a new door and a fender to start off but maybe one of you Nico catz has a good way to fix the frame.
Heres some pics I will get better soon
pleas helppplplpplplp
srpowered240sx wrote:body shop, frame puller. needs to be pulled straight, then filled smooth, new door, new fender, and considerable work on rear fender to make it straight (or a cut and weld fender section).
on second thought, rear could be hidden once pulled pretty straight with over fenders. good time for aero, will save you smoothing on the rocker panel too.
