SOMEONE HELP PLEASE!!!
khoolie
Car: 92' 240sx coupe
s13 SR20DET
Ok, my car was runnin prefecty fine all day. i drove to missisauga and back to hamilton, absolutly no issues at all, about 20 mins ago i went to pick up my girlfriend, on the way home i came to a red light and all of a sudden she started runnin REALLY rough. and when i push on the gas shes spudderin really bad!. i mean sounded like a helicopter. and really thick white smoke is pouring out the exhaust and it STUNK like fresh gas. i made it to my house. turned her off and when i tryed to start her again....nothing. shes crankin but wont start. she has been runnin really rich ever since the day i got her without issue, hense the black stuff all over my bumper... if that helps. please god someone help me!!! this is my daily driver and i need to fix it like yesterday!! i gotta work tommorow afternoon. please i know someone out there knows exactly whats wrong and how to fix it. thank you
khoolie
ok i pulled the plugs and checked for spark. all 4 have spark. when i turn the key i can hear the fuel pump turn on. all vacum lines appear connected, all intercooler piping is secured fine. when i was checking the plug closest to the firewall it shot fresh gas out of the engine. any ideas of what it could be?
Rucca
Did the car overheat or get hot when the white smoke was pouring out? If you have fuel and spark at all cylinders you probably don't have compression. White smoke = coolant burning so I'll guess blown headgasket.
khoolie
the car didnt overheat. the thick white smoke that was billowing out smelt purly like fresh gasoline. i think its somethin electrical because it was literally one sec the car was runnin perfectly fine and the next second it was all fukd up. it wasnt a gradual thing at all
khoolie
Rucca
Unburnt fuel should be black.
Anyway, did you check for codes? All you checked was spark and a cylinder had fuel in it. You need to check codes and check compression.
jismo
Car: flat red 93 240sx
i dont think his gettin any codes out that thing.how does it sound when it cranks? like normal i hope. or like its missing a stroke.
jismo
white smoke im thinking coolant.
jismo
did u fill up on gas some were? and did it rain where u r
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
It's not firing on one cylinder. Explain how you went about checking the spark.
