Daunttless »
https://forums.nicoclub.com/daunttless-u116.html
Wed Sep 11, 2002 10:11 am
There isn't a definitive list and you won't make big naturally aspirated power without heavily working the engine over. The mods you have are good, if you want more you'll need higher compression pistons but then you can never go turbo. You need two fans because ones a pusher and ones a puller. You don't want the crank pulley with the electronics you have, and sometimes they can cause bad harmonics, which with a vibration prone motor like the KA is never good. Thats the only downfall is your battery will drain because you won't be providing enough power to all that stuff and harmonics.
Standard Upgrades:1) Intake2) Exhaust3) Headers/Downpipe
Advanced Upgrades:4) Cams5) Higher Compression Pistons6) ECU Reprogram
There really isn't all that much to do unless you get into things like independant throttle bodies, which for some reason I know you don't want to do. : )
You would see more gains in suspension and handling than you ever will in standard naturally aspirated performance from the 240SX.
