someone help me please!!!!
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
DriftReadyS13
Car: 92 s13 w/ sr20
i got a gutted s13 . all interior was takin apart but in car. i took it all out and got ust the carpet back in. someone please help me . i dont know how to put the interior back together. the problem is the back bracket the goes under the armrest bezel. i dont know what bracket bolts to the frame in order for the two back screws on the trim piece to screw into. im lost at this. there are so many wires just hanging. i dont know where the harness or clips plug into .. im just a total noob at this interior thing. any info would help thanks!!!!
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Pics, I think I can help but I'm not sure exactly what part you are talking about.
DriftReadyS13
Car: 92 s13 w/ sr20
my didital camera isnt working... the center consle that goes between the two fronts seats. there is a hole on the passenger and driver side that screws go into to hold it into place. they are in the back closet to backseat. if u take that center console off i guess there is a bracket that goes under so those screws have something to screw itno and im not sure what it looks like. if you but just the console on there wont be anything for the screws to screw into
positron1
Not an excellent picture but you can see the bracket sitting behind the big copper box on the end.The factory part number is 96991-35F00.
DriftReadyS13
Car: 92 s13 w/ sr20
thanks.. i also didnt know that that box went there either. now i just got to figure out how to run the harness under the dash and to under the hood. i dont know what connects to what lol
positron1
What harness/harnesses are you running?
DriftReadyS13
Car: 92 s13 w/ sr20
i guess its the engine harness and it runs threw the firewall and the end piece with the blue connectors connects to the box in the pic u have above
DriftReadyS13
Car: 92 s13 w/ sr20
nevermind its not the same gold box. i dont even think i have that gold boxx.... man this is more then i can handle
positron1
If you are talking about the engine harness and the ECU(which looks kinda like that gold box). It's bolted to the chassis under the right kick panel near the front speaker in the door. It runs through a hole in the firewall under the dash.You can see it at the bottom of this pic.
DriftReadyS13
Car: 92 s13 w/ sr20
heres how the interior is sitting as we speak
DriftReadyS13
Car: 92 s13 w/ sr20
i have no idea where any of those clips or anything goesss
bmadd2402
Car: Twin Turbo-shaft UH-60L, 1992 RB-240sx
hey man. good luck with that mess!!! the nice thing is that all the clips are slightly different. and if they are mostly still all loomed up, they should be sitting in their approximate positions. I'd start at the dash board. put it in and pull all the connectors thru the holes they lie closest to. that should almost be all of them, then start with the trial and error. look at the connectors and plugs. I'd probably help to have an s13 you can reference. Like I said, good luck!
DriftReadyS13
Car: 92 s13 w/ sr20
thanks man! i appreciate it
positron1
Well I can tell you from experience that the harnesses around your steering column connect to the various buttons on your cluster bezel such as defrost, headlight retract, etc. Your best bet on those is to get your cluster bezel buttons and match up the harnesses with the button and label them for when you put the dash back together.
DriftReadyS13
Car: 92 s13 w/ sr20
hey positronone, if i take pix of brackets i have would u be able to show me or tell me where they went . al li have left is the dash and the center console
positron1
I will if I can!
DriftReadyS13
Car: 92 s13 w/ sr20
thanks. i should have them up sometime today
nomad88
Car: s13
wow, good luck man.
Return to “Interiors”
